Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Lost distributor Part?
04-28-2014 12:08:10
Thank you ever so much! I can't tell you how
much that means to me. I appreciate the fact that you took your time to post that information.
04-28-2014 13:04:26
 Re: Lost distributor Part? in reply to RMberme, 04-28-2014 12:08:10
I think I'll use a wire from the coil to the
points. Once again, thank you very much.
04-28-2014 12:28:57
if you hit a snag, just post or email back.
if you go the wire rout, just make sure it is out of the way of the advance mechanism.
some people LIKE having the more original copper strip. you can make it out of many things and be 'close'.
1, copper or brass foil from a hardware / craft store... cut with construction scissors / tin snips., drill holes at ends.
2, pound a short piece of 3/16 or 1/4 copper water line flat, drill 2 holes for ends.
3, I've even seen one made from a snip of galvanized tin roofing! worked fine! so i left it in place. still running a decade after i found it.
