TractorLinks.com
Show Parts for Model:
Re: Lost distributor Part?
soundguy
04-28-2014 12:01:25
it is a glorified compression grommet with a conductor thrut he center. copper strip on the inside connects to points, on the outside the wire from the other side of the coil primary.
if your is broke, you can use many things from license plate grommets, plastic fastener wall anchors with an end chopped off, a real grommet, a dab of silicone on a wire run from the coil to the points.. etc.. etc..
RMberme
04-28-2014 12:08:10
 Re: Lost distributor Part? in reply to soundguy, 04-28-2014 12:01:25
Thank you ever so much! I can't tell you how
much that means to me. I appreciate the fact that you took your time to post that information.
RMberme
04-28-2014 13:04:26
 Re: Lost distributor Part? in reply to RMberme, 04-28-2014 12:08:10
I think I'll use a wire from the coil to the
points. Once again, thank you very much.
soundguy
04-28-2014 12:28:57
if you hit a snag, just post or email back.
if you go the wire rout, just make sure it is out of the way of the advance mechanism.
some people LIKE having the more original copper strip. you can make it out of many things and be 'close'.
1, copper or brass foil from a hardware / craft store... cut with construction scissors / tin snips., drill holes at ends.
2, pound a short piece of 3/16 or 1/4 copper water line flat, drill 2 holes for ends.
3, I've even seen one made from a snip of galvanized tin roofing! worked fine! so i left it in place. still running a decade after i found it.
