Judson Marvin
This message is a reply to an archived post by KurtNEPA on March 19, 2012 at 11:55:40.
The original subject was "Re: Ford 600 hydraulics".
Hello I am having issues with my hydraulics on my 600. Last
year while using the tractor the hydro didn't seem to wanna
work till the tractor was warmed up and had been running
awhile. Just recently I changed all the fluids. There did appear
to be water in the oil as it was milky. Now that I've filled
everything to spec the arms go up kinda sluggish. If I idle the
tractor up. The arms stop going up or at a slower pace. If the
tractor is at idle they go up sluggish and will be jumpy in a way.
I've removed the cap on the pump several times until no air
came out when I removed the cap. Any ideas what the
problem is? I've looked for a filter or a screen but no luck
there. Pump needing rebuild? Thanks
