Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Anadolu Power Steering
Tracy Brown
04-21-2014 08:05:14
No, you cannot turn the gear around. It won't be any different.
Danny P.
04-21-2014 08:08:41
 Re: Anadolu Power Steering in reply to Tracy Brown, 04-21-2014 08:05:14
Not to argue with you but yes it will be different. The teeth are slanted not straight. The ones on the pump are slanted the wrong way for the tractor gear but if it was reversed they would match up. Thanks.
Bob
04-21-2014 10:44:15
 Re: Anadolu Power Steering in reply to Danny P., 04-21-2014 08:08:41
Tracy is correct.
hurleyjd
04-21-2014 09:57:23
What do you have to lose, take the gear off and see if it will mesh with the gears in the tractor. If it does then okay. Otherwise you might have to find the gear that would fit or another pump.
Sean in PA
04-21-2014 09:46:14
Danny P. said: (quoted from post at 11:08:41 04/21/14) Not to argue with you but yes it will be different. The teeth are slanted not straight. The ones on the pump are slanted the wrong way for the tractor gear but if it was reversed they would match up. Thanks.
If the slant were reversed they would line up, but reversing the gear will not reverse the slant. Hold the pump in your hand and take note of which way the gear teeth slant. Then turn the entire pump around in your hand so the gear is reversed and you'll see what we mean. Just want to point this out to you before you go through the trouble of trying to remove and reverse the gear.
This is the same as trying to thread a nut onto a bolt. it doesn't matter which side of the nut you put towards the bolt, it will still spin on in the same direction.
This post was edited by Sean in PA at 09:51:59 04/21/14.
Copyright © 1997-2015 Yesterday's Tractor Co.
