Yesterday's Tractor Co. Same-Day Parts Shipping Available
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Anadolu Power Steering
Danny P.
04-21-2014 06:22:04
170.141.177.87
I started installing my power steering kit on my 1967 3000 diesel this weekend and had a problem. When I started to mount the pump I found the gear is backwards from the gear on the tractor. Can I just turn the gear around on the pump? The instructions are basically a picture. Does anybody know where or who to contact with a problem with this kit? Does anybody know of a distributor in the US I could contact? I got this kit as part of a trade. It has 3000 on it and wasn't opened. Thanks.
[Reply]   [No Email]
Fordfarmer
04-21-2014 11:21:27
174.124.24.28
 Re: Anadolu Power Steering in reply to Danny P., 04-21-2014 06:22:04
Don't know for sure about that kit, but the drive gear for a factory pump has a tapered bore - it can't be turned around. Did you try it, and it won't fit, or does it just -look- like it won't fit? Sometimes, things that dont' look right DO work.
[Reply]  [No Email]
Tracy Brown
04-21-2014 08:05:14
192.208.128.64
No, you cannot turn the gear around. It won't be any different.
[Reply]  [No Email]
Danny P.
04-21-2014 08:08:41
170.141.177.87
 Re: Anadolu Power Steering in reply to Tracy Brown, 04-21-2014 08:05:14
Not to argue with you but yes it will be different. The teeth are slanted not straight. The ones on the pump are slanted the wrong way for the tractor gear but if it was reversed they would match up. Thanks.
[Reply]  [No Email]
Bob
04-21-2014 10:44:15
64.255.159.192
 Re: Anadolu Power Steering in reply to Danny P., 04-21-2014 08:08:41
Tracy is correct.
[Reply]  [No Email]
hurleyjd
04-21-2014 09:57:23
68.168.202.233
What do you have to lose, take the gear off and see if it will mesh with the gears in the tractor. If it does then okay. Otherwise you might have to find the gear that would fit or another pump.
[Reply]  [No Email]
Sean in PA
04-21-2014 09:46:14
76.98.64.154
Danny P. said: (quoted from post at 11:08:41 04/21/14) Not to argue with you but yes it will be different. The teeth are slanted not straight. The ones on the pump are slanted the wrong way for the tractor gear but if it was reversed they would match up. Thanks.
If the slant were reversed they would line up, but reversing the gear will not reverse the slant. Hold the pump in your hand and take note of which way the gear teeth slant. Then turn the entire pump around in your hand so the gear is reversed and you'll see what we mean. Just want to point this out to you before you go through the trouble of trying to remove and reverse the gear.
This is the same as trying to thread a nut onto a bolt. it doesn't matter which side of the nut you put towards the bolt, it will still spin on in the same direction.
This post was edited by Sean in PA at 09:51:59 04/21/14.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
