Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 2000 Parts Online
2000 -4cly fuel in oil
cdv
04-20-2014 18:01:27
just got a 4cly 2000 today I think it a 1962 SOS,,pull the dip stick fuel and oil mix come pouring out so dose that mean the pump is bad or is there a seal to replace I think it saids roseamaster on the pump be not sure and my manual dose not show the diesel tractor only gas,,, have not tried to start it yet,,thanks cdv
Texas!
04-20-2014 18:44:38
 Re: 2000 -4cly fuel in oil in reply to cdv, 04-20-2014 18:01:27
The 4 cylinder diesels have 2 common leakage prone areas: the umbrella seals on the pump driveshaft and the soldered excess fuel return line under the valve cover.
Larry NCKS
04-20-2014 18:43:40
There are threads on this if you search. However, in a nut shell, you have input shaft seals out in your pump or injector or return line leakage under the valve cover. Or possibly all of the above.
Edit: do not attempt to run that engine with that much fuel dilution in the crankcase!
This post was edited by Larry NCKS at 18:45:08 04/20/14.
