Jube + Loader
Beanmedic
1953 Jube addition to the family. Loader is a Kelley, which is still in business. Stinger pump with new tilt cylinder and hoses. Two valve control, but no down pressure on lift cylinders. (Is that common?). Clutch pedal indicates she has been worked quite a bit, but starts right up and has good oil pressure. Tires less than 2 years old. Tin is rough. Wiring cobbled and an automobile start switch . Lift oil milky.
I think bucket is going to be handy loading large oak chunks on low trailer, and I have quite a few from having trees cut down at my mom's house. Just remembered that I also have offer for some free compost. It will certainly be easier to unload with a bucket!
Lots of work to do. More pictures to come.
nice
yes, no down pressure was pretty normal on old loaders.
It'll still do what you need, just takes practice if
you are used to loaders with it.
pretty big bucket for a Jube, try not to overload it, to help out your frontend.
hang a big counterweight off the back and it will steer a little easier......a little :)
