Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 3000 Parts Online
Re: Ford 3000 PTO Shaft Leaking
04-20-2014 16:19:17
Ok pulled the shaft out. The Shaft doesn't appear to be bent from the naked eye. If push comes to shove I can put the Shaft on a precision lathe and check it by spinning it to see if its bent. The only suspect thing I could find was the razor thin gasket which was crumbling a little bit in the corners. The "assembly" seems to rotate just fine on the shaft. How would I know if there is a bad bearing or not? Also when I remove the bolts they didn't seem to take much effort to loosen...
04-21-2014 07:57:19
 Re: Ford 3000 PTO Shaft Leaking in reply to stevo7122, 04-20-2014 16:19:17
check for shaft to beairng play.. if none, and hte shaft looks true.. repalce the seal and gasket ( clean flanges ).. and see what you got. ps. check the wear ring. make sure it is not loose too!
