Home made wheel weights
I have been watching the thread about wheel weights.
I am appalled at the price for wheel weights and
then there is the transportation. Hasn't anybody
made any? Seems like you could cast some out of
concrete using a cut rubber tire as a form.
About 35 years ago, my dad had an old 9N that someone did the concrete rear wheel weight option to. They used a large diameter galvanized/metal drainage pipe for the inside mold, then the outside of the mold was simply the inside of the wheel rim. This was all facing inwards. I don't remember how they worked out the six bolts to hold the rim to the center, or even if they were six-loop rims. Been a long time.
I know they were unique, and about 10+ years after he sold the tractor and lost track of it, someone told us of a certain 9N they found that had these funny concrete weights inside the rear tire. We knew it was that tractor from the description...
(quoted from post at 09:22:43 04/20/14) I have been watching the thread about wheel weights.
ere are some & if you search YT site, you will find others.
here's a shot of my old 641. Welded a big piece of pipe to the center disc add some rebar or long bolts, a sona tube and pour the concrete. Ain't as pretty as the pie weights but works.
Kirk
