Have a Ford 8830, that the pro won"t shutoff properly.
When warm it would cycle properly, but when cold it would
take up to 20+ minutes before it would shut off. Revving up the
tractor would stop it quicker. But when warmed up it would
work properly.
Had into dealer , they replaced the break pads the hydraulic
pump ( the pressures were on the low side ), the shaft that the
clutch disc ride on was bad, and replaced. The clutch plates
were replaced, and some other linkages that were worn.
It worked much better, but still could take up to 3 or 4 minutes
to stop running when it was real cold. The only load put on the
tractor was a grain cart, and fert spreader.
A year later, it is now worse. It takes awhile to stop running
((after it is first started) but now it will not always shut off.
Sometimes now , I have to idle the tractor down in order to get
it to stop. But that does not work all the time.
Had it back into dealer. Everything is within range, (all on the
high side) .the only way to get it to work properly, is to restrict
the lubrication circuit. The problem then is that the hydraulic
restriction light comes on. Does anybody have a idea on how
to fin this tractor.
Thanks
Joe
work properly.
Thanks
Joe
