Dual Power Coil
There has to be a supplier for the coil that operates the dual power valve on TW25 and TW35"s! They used to be available from Ford for a cost of $60.00. Now you have to buy the complete valve assembly for $400+!! I"ve got 2 valves they are good except for the coil. Anybody had any luck finding one of these coils? Already tried Messicks and Alexanders. Thanks!!
A couple of years ago someone found a coil from another company, for another application, that worked. I think it was for a Bobcat or something like that. That's all I recall, however. You may find it by searching the archives.
Search diesel pup. He found one from Bobcat that fit. I have the tractor now and it is working fine.
You are right there has to be! I have recently taken to searching for this stuff on ebay. I have found that it is a way to find supply houses that carry the same parts, but just not specifically for Ford. I searched for 12V solenoid coil and got a lot. Of course it has to also have adequate duty cycle and correct tube diameter. But you could afford to buy a lot of incorrect ones for $400.00
Re: 7710 DP Solenoid in reply to dieselpup, 04-25-2013 11:45:12
I kept looking in the archives but couldn"t find it. edhohio found it for me. P/N 6671025. In stock at the Bobcat dealer (amazing). Better Half will pick it up for me later this morning. Will give update once I see how it works.
A lot of these parts are out there at the places that CNH buys them from at a fraction of CNH prices. Someone should put together a list of vendors. We could save tens of thousands.
I had to supply and fit one of these last week to a Ford 555 backhoe loader, the same valve is used for the clutch dump.
$1,238.00 NZ, that is $1,061 US!
You are quoting $466NZ, we would have been happy with that! We could not find an after market coil winding to fit the valve, and the tractor wreckers knew exactly how much to charge for used, and CNH know what to charge for new, a total rip off.
