Lanexa Speedway
I have my Sherman high/low combo transmission all apart right now. Got a rebuild kit and have all good parts now, with the exception of one seal. It is a seal that goes around the shift shaft.....the shaft that pokes out the side of the top cover.
Attached is a picture of the location from John Smith's web site and rebuild procedure. The shaft I'm talking about has the square end that the shift handle attaches to. However, the shaft/top cover on the one he's working on does not have a seal. Mine does. It's a 3rd generation unit per John's identification guide.
I pulled the seal out of mine before realizing that I didn't have one to stick in there, and there is no number to be found on the mangled mess that remains. I do know that the OD is 1", the shaft is 11/16", and the thickness of the seal is in the 0.156" range.....about 5/32" thick. Have been trying to find catalogs to poke through for a reference, but no luck yet.
Anyone know the part number for this rascal?
Thanks,
Kevin
Thanks,
Kevin
