I have a 70s Ford Industrial 515 which is very similar to the more common 4600. When I try and raise my 3 pt it will not move until i pull the position control almost all the way to top position. Draft control up and draft control down makes no difference. As it"s raising I can bump the position lever down until it stops and it does hold without leaking its way back down.
Any ideas on what may cause this?
Very little adjustments as I can see. I have turned the flow control down so it is easier for me to stop stop the system where I want it. Fast or slow though it does the same thing.
