Ford 772 Loader - Quick Release Bucket
Brian in MA
I'm looking to add some flexibility to my 5600 loader and put a Bobcat style quick release bucket on. I normally build this stuff from scratch, but I'm wondering what others have done/where I can find the tractor side of the quick release bucket setup that will work on my Ford series 772QT loader. Any thoughts/links would be appreciated.
Thanks.
I bought a universal skid adapter for a 7410 loader several years ago from Horst (HLA)... If I was doing it again I would just build one. I ended up tearing this one half apart and rebuilding it to make it fit correctly because in spite of them telling me that it should fit.... it did not... and I didn't want to get hooked for freight to return it. The pin geometry was incorrect for this loader and it had zero rollback when installed. Their solution was to install wedge blocks on the attachments to correct the rollback. That was no good to me because I wanted to use NH attachments... and NH loaders achieve rollback on the plate, not the attachment... The concept behind it is good... and mabey some of their other models work better but he execution on this one was not great. It's also a bit lightly build for a heavy farm loader. Even the skid's have a much heavier adapter plate... so if you buy, make sure you watch out for fit, rollback and whatever other tricks they might play.
Rod
