Hello,
I have a model 3000 series tractor that keeps blowing out the pressure line ( small line) that goes to a pump from the transmission. The line goes out the right side of the trans under the gas tank to a pump of some sort and then the larger return line goes back in the trans next to the supply line. Before I got the tractor it was leaking from the fitting and my uncle put a new rubber cup type replacement o-ring and it seemed to fix the leak but while I was running it blew out and blew oil everywhere. Any help would be appreciated. It has as 8 spd trans.
Thanks
Thanks
