TractorLinks.com
Order Ford 801 Parts Online
Re: 801 Powermaster Pertonix Ignition
Clint(oh)
04-06-2014 14:40:47
Ok, I ran the black/white wire to dist. side of the coil, there is a wire from the starter solenoid (s) going to the batt side of the coil. I ran the black wire to the ignition wire and I dont have anything.
JMOR
04-06-2014 17:15:51
 Re: 801 Powermaster Pertonix Ignition in reply to Clint(oh), 04-06-2014 14:40:47
Clint, I am quoting you here :
"Connect black ignitor wire directly to the ignition switch wire...
Connect black/white wire to negative side of ignition coil...
Connect an insulated awg 20 copper stranded wire from the positive coil terminal to the positive battery or chassis...
The black/white ignitor wire and the awg 20 copper wire should be the only wires connected to the coil "
Now just follow your own words.....which includes, "The black/white ignitor wire and the awg 20 copper wire should be the only wires connected to the coil '. That means get rid of the wire coil-to-solenoid! AND ADD, "Connect an insulated awg 20 copper stranded wire from the positive coil terminal to the positive battery or chassis...".
