Ford 4000 4cyl gas carburetor ID
Where do I find the model number on a Marvel-
Schebler carburetor. I ordered an MS101 economy
gasket kit from YT and the bowl gasket is to
small. Thanks Doug
You ordered the kit for the small TSX carbs. You should have ordered a MS102 kit for the large carbs.
On the TSX carbs used on Fords there was a brass tag riveted to the carb with the TSX number, Ford's number and the date of manufacture. Your 4000 left the factory with a TSX-813 on it. If the tag is not there measure the diameter of the air inlet just above the throttle plate. It should be 1.3125" (1-5/16") or larger.
