Ford 515 injector return routing
Hi I'm in the final stretch of finishing my ford 515 diesel the person before me removed the injectors and return lines and I don't know where they go I'm lost even with the service manual. There is one tube left on the injector pump on the back side then to where this is the last thing I need to do before bleeding it the starting it any help would be great thanks[/list]
Return fitting on the back side of the pump connects to #1 injector, then #2 and #3, connects at the back of th ehead to a separate tube leading up to a small nipple on the fuel tank filler neck. if you have thermostart, that 'T's into the return line at the top of the fuel tank.
