Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 801 Parts Online
Re: 801 Powermaster Pertonix Ignition
Clint(oh)
04-05-2014 12:07:36
The instructions say...
Connect black ignitor wire directly to the ignition switch wire...
Connect black/white wire to negative side of ignition coil...
Connect an insulated awg 20 copper stranded wire from the positive coil terminal to the positive battery or chassis...
The black/white ignitor wire and the awg 20 copper wire should be the only wires connected to the coil
Since my first post I checked the resistance on my coil and it is only at 1 ohm and the intructions say to have a minimum of 1.5 ohms so in the mean time I will be ordering a new coil
JMOR
04-05-2014 12:11:57
 Re: 801 Powermaster Pertonix Ignition in reply to Clint(oh), 04-05-2014 12:07:36
Quoting Removed, click Modern View to seeClint, are you now clear on the instructions or do you still have a question?
Clint(oh)
04-06-2014 14:40:47
 Re: 801 Powermaster Pertonix Ignition in reply to JMOR, 04-05-2014 12:11:57
Ok, I ran the black/white wire to dist. side of the coil, there is a wire from the starter solenoid (s) going to the batt side of the coil. I ran the black wire to the ignition wire and I dont have anything.
JMOR
04-06-2014 17:15:51
 Re: 801 Powermaster Pertonix Ignition in reply to Clint(oh), 04-06-2014 14:40:47
Clint, I am quoting you here :
"Connect black ignitor wire directly to the ignition switch wire...
The black/white ignitor wire and the awg 20 copper wire should be the only wires connected to the coil "
Now just follow your own words.....which includes, "The black/white ignitor wire and the awg 20 copper wire should be the only wires connected to the coil '. That means get rid of the wire coil-to-solenoid! AND ADD, "Connect an insulated awg 20 copper stranded wire from the positive coil terminal to the positive battery or chassis...".
