TractorLinks.com
Order Ford 4000 Parts Online
Re: TDC Ford 4000 3 cyl diesel
Ultradog MN
04-05-2014 09:20:03
Why don't you give me a call.
Easier to talk you through it than try to type.
612 968 5248
jwjsr
04-05-2014 16:43:35
 Re: TDC Ford 4000 3 cyl diesel in reply to Ultradog MN, 04-05-2014 09:20:03
Got em all adjusted, I must have loosened this one before I cracked it as the feeler shows it is adjusted correctly. I don't think it is cracked further down and will be fine.
i would say it took between 1/8th and 1/4 of a turn on all of them
I was worried if it is further cracked it would break up later and damage the engine but my local mechanic says it would have fall down into the oil get sucked up in the oil pump to damage the engine and that is not likely so not to worry.
One of my manuals mentioned a box wrench, now i think know why, I used an open end and noticed it wasn't a real tight fit and i didn't have it all the way on the nut and it exerted pressure in the wrong spot causing the nut to crush.
This post was edited by jwjsr at 17:09:46 04/05/14.
sotxbill
04-06-2014 07:52:10
 Re: TDC Ford 4000 3 cyl diesel in reply to jwjsr, 04-05-2014 16:43:35
lots of water on the valves?? you may want to run it for a few minutes and then change the oil...
jwjsr
04-06-2014 10:53:19
 Re: TDC Ford 4000 3 cyl diesel in reply to sotxbill, 04-06-2014 07:52:10
Thanks for the observation, that water you see is rain sprinkling, and i changed the oil just prior to the pic.
jwjsr
04-05-2014 09:25:34
ok let me put some shoes on and I'll walk out to the tractor
