I'm trying to adjust the valves and haven't done it but maybe once in my life and never on my tractor.
the owners manual says TDC is marked on the flywheel and that you can find the mark via the flywheel inspection hole which i found but I have questions.
1. What does the TDC mark on the flywheel look like? I found one spot with a bunch of numbers and at another point a black mark- kinda oblong.
2. Which cylinder is #1
3. I can't get my feeler gauge between the rocker arm and the valve tip of any of the valves? I haven't turned any adjustment nuts yet.
Thank you!
Winston
Thank you!
Winston
