This is my first compression test so I wanted to run the findings by you more knowledgeable individuals.
For starters, I was not able to run the engine to get it up to operating temp before completing the test. I have a no spark issue at the plugs that I need to troubleshoot.
I ran the test with all plugs out and the coil disconnected from the distributor. The first numbers in cylinder order are 74 52 63 82. I then poured a little SAE30 in the spark plug holes and turn the engine with the starter for a few revolutions. The next numbers in cylinder order are 185 145 180 140.
Based on what I have read on here the 180 numbers seem extremely high. Also, I believe this points to worn rings and an engine overhaul would be in order.
All feedback is appreciated.
Thank you in advance.
Thad
Thad
