Hi i just replaced the instrument cluster and a lot of the bulbs are bad. I think i found replacement bulbs at an auto parts store but I also found L.E.D. equivalent bulbs (High output not the weaker ones) of the same output and same bulb number but only require a fraction of the voltage. Will this work as long as the bulb type is the same? The plus side is L.E.D. bulbs don't burnout with excessive heat and vibration like the originals and don't get hot. The L.E.D.s are a direct replacement bulb so no changes are necessary. I'm needing this as a working tractor right now so I'm not to interested in authenticity.
