TractorLinks.com
Show Parts for Model:
Re: Conversion
soundguy
04-03-2014 06:20:59
You CAN keep the old 6v coil and add a resistor.. OR you can get a new coil. napa IC14SB is about a 15$ coil, and needs no resistor. It's what I use on all my 12v gassers.
As for the 1 wire alt. I find them less desireable.
see if you can make it run 3 wire. IE. jump charge stud to #2 spade, then with it running at 400 rpm, hit #1 spade with power and see if the alt turns on. if it does, get a 194 lamp and run a line from the coil side of the key thru the lamp to the #1 and have a 3 wire alt...
