TractorLinks.com
Order Ford 841 Parts Online
Re: 841 timing marks only visible when #4 fires - huh?
showcrop
04-03-2014 05:01:41
Distributor shaft bushings do wear out you should not be able to wiggle the top of the shaft it should be just loose enough to spin easily.
William Fissell
04-03-2014 07:44:59
 Re: 841 timing marks only visible when #4 fires - huh? in reply to showcrop, 04-03-2014 05:01:41
negligible wobble. Just the rotor is trashed.
Mark Slater
04-03-2014 15:08:13
 Re: 841 timing marks only visible when #4 fires - huh? in reply to William Fissell, 04-03-2014 07:44:59
Once you get the correct rotor with the clip the jitter will probably be less.
JMOR
04-03-2014 16:28:44
 Re: 841 timing marks only visible when #4 fires - huh? in reply to Mark Slater, 04-03-2014 15:08:13
Quoting Removed, click Modern View to see"Probably" not, as Bob has already stated, " Spark occurs when the breaker points OPEN and the statement "the rotor is slapping around so much that the timing isquite jittery now" is NOT valid"
