TractorLinks.com
Show Parts for Model:
Re: fuel filter gasket
showcrop
04-02-2014 05:48:01
Can't tell what you have without looking, but it is real easy to squeeze the correct gaskets out of place.
JonB
04-02-2014 10:28:23
 Re: fuel filter gasket in reply to showcrop, 04-02-2014 05:48:01
well, the old gaskets are about 1/16" thick and 1/2" wide, so even if they squirm a bit will still seal. I should have mentioned one new gasket will fit inside the filter bottom, but the other is larger diameter, and won't fit either end.
showcrop
04-02-2014 10:58:36
 Re: fuel filter gasket in reply to JonB, 04-02-2014 10:28:23
Neither of my diesels came with a gasket anywhere near a half inch wide, and all of the subsequent filters have gaskets very nearly the same as what came with them. I have had one for about twelve years and the other for about ten. I just checked a filter on the shelf and the gaskets appear the same as always. These are all WIX filters.
JonB
04-04-2014 14:29:49
 Re: fuel filter gasket in reply to showcrop, 04-02-2014 10:58:36
ok. Here's a picture of a wix filter. http://www.amazon.com/Wix-33165-Cartridge-
Canister-Filter/dp/B000CSD2HI
You can see the bottom gasket is at least 3/8" wide. Top gasket doesn't show, but it needs to be about the same. The filter on the tractor is a Ford/New Holland 305931 with wide gaskets.
I found some gasket material at Autozone that should stand up to diesel.
Hope this helps someone else trying to use Baldwin filters.
