TractorLinks.com
Show Parts for Model:
Re: ford 545A throttle
Rustytractorguy
03-31-2014 07:31:49
I would start at the fuel tank and check for cleanliness and flow. There should be a little fuel shut off in the base of the tank. There is also a filter in the shut off assembly. From there, there could be crud in the lines, dirty filters, worn injectors, etc. Those are easy (and free) things to check rather than spending money and throwing parts at an unknown problem.
Either way I'd change all fluids and filters regardless of what the seller said. That way you know what you have.
dick benson
04-01-2014 20:24:12
 Re: ford 545A throttle in reply to Rustytractorguy, 03-31-2014 07:31:49
New filters and new fuel. Added pint of Risolin additive. Plenty of fuel to filters. Tractor runs good at full throttle. I have to have it on full throttle to start. If I idle it down real slow it stays running and will run fine at an idle and I can slowly rev it back up. It takes a while to rev up ery slow to respond. If I idle it down quick it will die?and v
Rustytractorguy
04-01-2014 21:01:08
 Re: ford 545A throttle in reply to dick benson, 04-01-2014 20:24:12
Does the engine have good power at higher RPMs or have you not worked it yet?
dick benson
04-02-2014 06:23:07
 Re: ford 545A throttle in reply to Rustytractorguy, 04-01-2014 21:01:08
I don't think it has good power. When I loaded it, it struggled to get on the trailer. At first I thought it was the torque converter.
Rustytractorguy
04-02-2014 06:30:59
 Re: ford 545A throttle in reply to dick benson, 04-02-2014 06:23:07
Do you have the equipment to do a compression test?
