TractorLinks.com
Order Ford 601 Parts Online
Tie rod end replacement 601 with power steering
sstra
03-30-2014 14:17:28
See picture - How do I replace the rear tie rod end on a unit with power steering. Looks like the rear end is weld on to the end of the tube.
Is it replaceable? Do you cut it off and weld on a new one? And if so would anyone have a part number and vendor that I can order it from?
Thanks
soundguy
04-01-2014 07:33:03
 Re: Tie rod end replacement 601 with power steering in reply to sstra, 03-30-2014 14:17:28
slip a sleeve on the cut part so after you weld it you can slip the sleeve over and weld that too for more strength
sstra
03-30-2014 14:38:56
Thanks John and Ultradog MN for the reply.
Ultradog MN - - yours looks better than OEM.
John Smith8N
03-30-2014 14:33:20
On the rear end they were not replaceable so you have to cut the old one off and weld a new one back on. You want the NAA33271A ends, about $14 each from numerous aftermarket suppliers. This site probably has them, or Google that number for other sources.
Ultradog MN
03-30-2014 14:32:45
You can buy new tie rods but they are very expensive.
I just weld new ones on. Buy the ends for a non ps model - they will fit. Then cut the old ones off and weld the new ones on.
A little grinding, bondo and paint and you can't tell.
