Yesterday's Tractor Co. Trusted Parts Supplier since 1995
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Ford tractor
green meadows
03-29-2014 17:45:06
209.173.184.110
My book on my ford tractor says for ford 600 and 800 series tractor There is a 800 series tractor emblem on the front of the tractor does anyone know if this tractor is a ford 801 also doe anyone know what type of fluid the power takeoff takes
[Reply]   [No Email]
Royse
03-29-2014 20:21:17
69.36.49.186
 Re: Ford tractor in reply to green meadows, 03-29-2014 17:45:06
My favorite reference is John Smith's website here.
Without knowing what model tractor it is, it's hard to give advice
on fluids, but x00/x01 Fords are fine with M2C134D UTF AFAIK.
[Reply]  [No Email]
soundguy
03-29-2014 18:23:44
207.30.46.70
tin and emblems mean little. they can get swapped.
check the model id on the trans, then sn to get an age idea.. then check block casting to see if that engine matches size and date range..
tin, tranny, engines.. etc. lotsa swaps in 50-60 -70 ys.. etc..
[Reply]  [No Email]
Scott(Ks.)
03-29-2014 19:36:20
208.66.88.195
 Re: Ford tractor in reply to soundguy, 03-29-2014 18:23:44
For sure what soundguy said. You really don't know what you have until you check (all) the numbers. Here is my shining example. It started out as a 641 diesel, got a 134 gas engine replacement, got late 800 sheet metal. It is a good running frankentractor that really doesn't look to bad. A lot of changes can be made in 55 years.
[Reply]  [No Email]
TONY JACOBS
04-01-2014 08:27:49
172.162.13.24
 Re: Ford tractor in reply to Scott(Ks.), 03-29-2014 19:36:20
Hello Scott , Sorry you are wrong , That is 801 series sheet metal which completely different from 800 series sheet metal since they are both different tractors . The rear fenders between the two series are different as are the hood side panels the grille and the center section where the emblem bolts on . The real problem is most guys don"t know the difference between NAA"s , 600/800 , 601/801 , 2000/4000 so they don"t even know what they own especially if someone else switched parts around before they bought their tractors . Thanks Tony
[Reply]  [No Email]
soundguy
04-01-2014 06:01:29
108.112.48.116
looks like a good worker!
I have a frankie as well. mostly a 950, but parts sewed on from 7-8 other tractors!
[Reply]  [No Email]
jeff pk
03-29-2014 17:56:15
50.39.148.218
check out this info:
Look for a serial number on the flat spot by the starter motor---should also have a model number there
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
