Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 4000 Parts Online
Re: 65 ford 4000 pto
Sean in PA
03-23-2014 07:59:39
If the 2x4 didn't stop it then that means the clutch is not disengaging, so it's most likely not the brake. It's most likely the clutch plates are warped so they don't disengage. Slightly less likely is the clutch spring is broken. If you're going to have it apart to fix whatever is wrong with the clutch anyway, you should probably do the brake at the same time since it's been spinning with the brake applied and is likely worn as well.
