Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 4000 Parts Online
Re: 65 ford 4000 pto
fairguy10
03-22-2014 14:13:08
It has a 10 speed... its not a select-o-matic ... 4 forward with high and low sides
soundguy
03-22-2014 17:09:51
 Re: 65 ford 4000 pto in reply to fairguy10, 03-22-2014 14:13:08
10spd but NOT SOS ??
are you perhaps counting 8 forward gears and 2 reverse as a 10speed?
that's an 8spd twin stick just to clear things up.
if you count reverse.. then SOS are 12speeds. ;)
fairguy10
03-24-2014 09:50:13
 Re: 65 ford 4000 pto in reply to soundguy, 03-22-2014 17:09:51
Yes it has 8 forward gears and 2 reverse with two shifting levers. I did put a 2x4 against it and it wouldn't stop...would chew the 2x4 up. I did try to turn it when it was not running and it will turn...someone wanted to know that???
I guess it sounds like the clutch no the break from what I've been reading. That means we have to separate the tractor... I guess maybe a job for someone else. And put in most the new parts as long as we are in there..
Thanks again for all your help!!
soundguy
03-24-2014 11:16:58
 Re: 65 ford 4000 pto in reply to fairguy10, 03-24-2014 09:50:13
sounds like a control valve issue.. it is staying powered.
if it was a piled up or warped clutch.. it would have been stiff when off.
Copyright © 1997-2015 Yesterday's Tractor Co.
