Minifarmer
New User
I wd like to adjust the valves I looked in IT service manual..there are instructions to adjust valves and refers to place the engine on TDC timing mark. I looked for an hole in the casting that permits to see the timing mark on the flywheel did not find one. Does somebody knows where to look ?
Is it possible to remove the starter without remove the injection pump...seems very little clearance in between.
Thanks in advance
Minifarmer
Thanks in advance
Minifarmer
