Yesterday's Tractor Co.
Shop Now View Cart
Order Ford 841 Parts Online
Re: 841 - Radiator Problems
03-21-2014 20:28:25
Slips in the hole? How does it attach to the radiator? Is it a carriage or plow-type bolt, or something else?
We figured the bolt was welded or soldered onto the radiator.
03-23-2014 16:43:44
 Re: 841 - Radiator Problems in reply to radara4077, 03-21-2014 20:28:25
Not welded. There is a half round and slot on the bottom of the radiator that lets you angle in a carriage bolt. The square on the carriage bolt needs to wind up in the slot to keep it from turning when the nut is loosened. Most likely your is out of the slot. You could try moving the radiator to the side using a mallet and wood block. If you cannot get the radiator to move side to side, drill the bolt from the center of the nut (that's what I did).
03-21-2014 20:35:24
The radiator bolts are common carriage bolts. Anti sieze upon reinstallation with new bolts and nuts. DO NOT overtighten.
Install new radiator pads.
Buy a salvage front axle pin retainer. This would be a good time to remove the pin and install new bushing and (probably) pin.
