Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 600 Parts Online
Re: ford 600 wiring problems
soundguy
03-21-2014 17:05:27
rewired and now nothing. not even starter?
what ELSE did you do that you aren't telling us?
change key switch?
change start solenoid.
these are the easiest tractors to wire.
for basic testing, a wire from the oem thumb starter switch to the solenoid trigger terminal, bat and starter hooked up.
wire from bat ot thru key to coil primary 1 side.. other side primary out to dizzy, coil secondary to dizzy cap.
that will MAKI it run .. no amp gauge., no charging.
to get charging vreg fld to genny fld, genny arm to vreg arm (gen). vreg bat out to hot side of starter relay, going thru ammeter.
put that hot wire going to key switch on same side of ammeter as vreg bat wire and you are BASICALLY wired to charge, show ammeter net charge, start and run.
Copyright © 1997-2015 Yesterday's Tractor Co.
