TractorLinks.com
Show Parts for Model:
Timing mark Ford 3 cyl diesel
Minifarmer
03-21-2014 16:19:04
I wd like to adjust the valves I looked in IT service manual..there are instructions to adjust valves and refers to place the engine on TDC timing mark. I looked for an hole in the casting that permits to see the timing mark on the flywheel did not find one. Does somebody knows where to look ?
Is it possible to remove the starter without remove the injection pump...seems very little clearance in between.
Thanks in advance
Minifarmer
Ed_F
03-22-2014 04:21:06
 Re: Timing mark Ford 3 cyl diesel in reply to Minifarmer, 03-21-2014 16:19:04
The starter comes off without removing anything else.
The difficult part is getting the rear bolt out and back in. Try a 9/16" socket (3/8" drive), a 6" wobble extension, a 2-1/2" wobble extension, and a 3/8" ratchet. The wobble extensions give you flexibility to work with some misalignment.
RickB
03-21-2014 16:21:52
In the steel cover plate behind the block and in front of the flywheel. Right side below the oilpan rail.
