Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: getting an early start
rd 2n in mo
03-21-2014 07:41:53
It seems that your rotor clip is pointing to #4 plug. the brass end will send the current to #4.
rotate the dist. to #1 which is 180 from there and re attach your cap.
you were shown the correct set up yesterday with another f-2000.
firing order is 1 2 4 3 with #1 being at the front of the tractor.
#1 on the distr. is directly opposite from the #4 you have shown.
if this does not work then pull your plugs and rotate the motor until you find compression on #1 piston. at that point you should have tdc on that piston AND you should have the correct location for #1 on the distr.
reinstall the plugs and put the cap back on and it should fire up.
03-21-2014 16:22:53
 Re: getting an early start in reply to rd 2n in mo, 03-21-2014 07:41:53
No wonder the poor guy is confused with such conflicting information. Do not rotate the distributor base. It was running before, so it is only a matter of getting wires back the way they were.
