Yesterday's Tractor Co. Same-Day Parts Shipping Available
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Rotary mower
Rustytractorguy
03-21-2014 02:32:56
180.94.85.16
What size rotary mowers are suited for a 545 (201 diesel)? Is a 6' to big? Will be cutting grass and some brush mostly under 2" diameter.
[Reply]   [No Email]
soundguy
03-21-2014 15:41:08
207.30.46.70
 Re: Rotary mower in reply to Rustytractorguy, 03-21-2014 02:32:56
my 4600 ( 201 ) swings an old heavy-heavy servis mower thru 'junk' quite nicely.
[Reply]  [No Email]
RodInNS
03-21-2014 08:33:22
216.118.158.123
In light going it'll handle a 7' OK. In heavy going... 6' is plenty.
Rod
[Reply]  [No Email]
Rustytractorguy
03-21-2014 07:55:47
180.94.85.16
Thanks for the input guys. I figured it would work but I just didn't what to overwork the engine and PTO drive line, and if it's think I'm happy to have IPTO!
[Reply]  [No Email]
sunbeam
03-21-2014 05:44:44
70.195.1.159
The 3 point category should be a clue. I would replace the top link with one made of chain or not use a top link so it will flex when going through a low place.
[Reply]  [No Email]
Rustytractorguy
03-21-2014 07:37:23
180.94.85.16
 Re: Rotary mower in reply to sunbeam, 03-21-2014 05:44:44
Luckily, our land is almost flat as a board. The tractor is also capable of Cat 1 and 2, I might just have to buy a different top link. I have the balls for the lower arms already.
[Reply]  [No Email]
Ultradog MN
03-21-2014 04:56:27
174.20.239.172
You want at least a 6' on it.
If the mower is a light duty unit you could go 7'
My 3000 handles a heavy 6' Bush HogŪ just fine.
Front end get a little light but not too bad.
[Reply]  [No Email]
s19438
03-21-2014 05:07:57
108.36.215.249
 Re: Rotary mower in reply to Ultradog MN, 03-21-2014 04:56:27
no stabilizer bars or was this just a photo op ?
[Reply]  [No Email]
Ultradog MN
03-21-2014 05:29:12
174.20.239.172
 Re: Rotary mower in reply to s19438, 03-21-2014 05:07:57
Photo op.
I modified the 3 point on it as it was set up for cat 2,3
Changed it to cat 1,2
Then bought stay bars.
First time I've ever used them on anything.
[Reply]  [No Email]
s19438
03-21-2014 14:05:43
108.36.215.249
 Re: Rotary mower in reply to Ultradog MN, 03-21-2014 05:29:12
neat !
[Reply]  [No Email]
Sean in PA
03-21-2014 04:21:22
76.98.64.154
It should have no problem handling just about any 6' rotary mower. I have an old heavy duty Woods 5' on the back of my '73 4000 with the gasoline 201 engine and it doesn't even know it's back there. I go over saplings as big as 1.5" in diameter and it chops them up like you put them through a wood chipper.
Looking at the specs on that mower, it says that it's for tractors in the 30 to 120 hp range, which is a pretty wide range, but the PTO on your tractor should be somewhere between 50 and 55 hp, so it should handle it fine. The specs also say that it's capable of cutting things up to 3" in diameter, but I would guess that is probably only when hooked to tractors in the upper end of the rated hp range, but as long as you stay under 2" I would think that you would have no problem. I've never tried to cut anything over 1.5": with mine, but from the results so far I don't doubt that mine could handle 2" easily.
[Reply]  [No Email]
woodbutcher
03-21-2014 03:50:13
38.114.125.178
Rusty,
I'd say it depends on the brand. I pulled a 10' Howse(HICO) with my 4610 without any problems, but I would not have tried to pull a Mohawk or Servis(Rhino) of that size. I don't know of any other brand that is as light as the Howse, but I sure wouldn't recommend it for heavy brush-cutting.
Butch
[Reply]  [No Email]
rustytractorguy
03-21-2014 03:56:21
214.27.58.2
 Re: Rotary mower in reply to woodbutcher, 03-21-2014 03:50:13
I am looking specifically at the Woods BB720X.
[Reply]  [No Email]
Dean
03-21-2014 06:17:35
24.1.134.162
 Re: Rotary mower in reply to rustytractorguy, 03-21-2014 03:56:21
The BB720X would be a good choice.
I use a BB720X with a MF 533. The 533 is the 2007 modernized version of the 135 with a NA 202 CI Perkins engine rated at 45 PTO HP.
With 4 front weights, the 533 handles the 720X well but I sometimes find myself in low/2nd in the very heavy stuff.
I would not go to 7' unless it is light and the cover that you plan to cut is also light.
I also have a 7' BB840X that I use with a 60 PTO HP FWA MF 2635 (220 CI turbo engine). I've found myself in low/3rd in heavy stuff before and can imagine situations where the mower would not clear well requiring low/2nd.
Dean
[Reply]  [No Email]
Brian in MA
03-21-2014 04:13:32
70.91.218.113
The Woods 720 would be my first choice for that size tractor.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Posting Help]  [Return to Forum]   [Add a Reply]
TRACTOR   PARTS TRACTOR   MANUALS
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2014 Yesterday's Tractor Co.
