Ford 4000, Hole in hydraulic line that runs from pump to ...
Robb-PA
New User
On our Ford 4000 tractor I have a holes in the metal hydraulic lines that run from the hydraulic pump to where they go into the rear end. I need to get the lines off in order to get them brazed. Where they go into the rear end it looks like they go thru a flat plate directly into the rear end. Is there anything behind that plate,springs, o-rings etc.?? or how do I go about getting the lines out of the rear end. I cant find anything in the manual on this.
