Ford 3000 3 pt won't raise
Rich Wright
New User
I was running a 3pt seeder tonight on ford 3000 when I lowered it to refill it would not raise back up. I checked oil level and its good,I worked the remote and it feels like that puts pressure on hyd lines. I flipped the draft lever without effect. I haven"t done anything else yet. Any suggestions on where to start? Its a 1972 diesel about 3400 hours. Thanks Rich W
Rich Wright,
If you have 2 remotes, check the handle for the other remote. I bumped a handle one time and because the remotes get pressure first, that starved the 3 pt. Scratched my head for a while on that one.
HTH
Keith
Thanks for comments.
It only has one remote, I plan to double check tonite by hooking a remote cylnder to it to make sure its pumping oil. Any suggestions on what all I have to disassemble to check the linkage on the 3pt? Just take remote valve off which sits on top of case? Is there an inspection plate?
I"ll keep you posted once i get home tonight and start into it.
