William Fissell
Hi, All,
subject line says it all
- carb rebuilt
- valve train replaced and regapped
after ignition is shut off tractor will run more
or less indefinitely on 1-2 cylinders; eventually
one will fire before tdc and the engine will run
backwards and that puts a halt to it. I can kill
it under a load or put the throttle wot and the
influx of cool gas seems to kill the dieseling.
Temp gauge barely into green.
Anything else I should do?
thanks in advance
Bill
- carb rebuilt
thanks in advance
Bill
