Winston Jones
New User
I have a Ford 4000 1971? with 3 cyl diesel.
The injector pump is leaking from the throttle shaft. I am going to use the below links to reference part#'s and help to remove the top cover and replace the o-rings on the throttle and cut-off shafts as well as the top cover gasket.
What other parts would you advise I change while I have the top cover off? And where can I order them online? see diagram in second link below for parts blowup.
The tractor runs fine but often requires a shot of starting fluid especially after it is hot.
Should I also refresh some parts in the end cap with the filter in it. Reference is part # 1 of the 2nd link below.
I can tell from researching it I am not qualified to really go any further than removing the top cover, and like i say it is running fine.
Thks for looking!
Winston
http://www.solidebolide.nl/downloads/CAV%20Workshop%20Manual%20fuel-injection-pump.pdf
http://www.tractorforum.com/attachments/f203/19880d1384252212-ford-4000-3-cylinder-injector-pump-issue-cav-fuel-injection-pump-diesel-2000-3000-4000-65_-5000-11-72_-1-.pdf
Thks for looking!
Winston
