flail mower
s19438
I can find no drain plug on the gear housing and I need put clean oil in it as the present oil is badly contaminated with water.
I see two options:
take the cover plate off which I do not want to do or run the mower on a good and hot day and suck said oil from drain plug.
might I be missing something ???
thanks.
oops! forgot pic.
I had a mower once with only one "fill" plug. Instructions said to turn the entire thing upside down to change the oil out. It worked but what a mess. Ended up drilling the bottom of the case and installing my own drain plug.
Moral to the story: Ya might have to come up with your own solution, so it works for you.
