TractorLinks.com
Order Ford 841 Parts Online
Re: Automobile genny on 841 - which VR and coil?
soundguy
03-07-2014 13:44:57
since I can remember, this forum has reccomended the napa IC14sb round coil for 12v applications.
I see no reason to deviate.
as to your gen / reg situation..
I find it extremely hard to believe you are seeing a closed circuit voltage of 10v in a system with a 6v battery.
IF the gen was making 10v at load. something would have let smoke out long ago!.. thus i suspect your testing or observation procedures are in error.
is it still set up as B circuit?
what does a full field test show you on the ammeter thru a range of rpms from idle on up?
William Fissell
03-07-2014 14:26:21
 Re: Automobile genny on 841 - which VR and coil? in reply to soundguy, 03-07-2014 13:44:57
Soundguy,
I kinda agree on the smoke issue. For example, the battery is fried and won't take a charge on the charger. The VR does nothing- ie the contacts aren't chattering, plus bits of the wiring harness had burned/melted through.
I redid the harness and turned it on just.... long... enough.... to....see... 10V...and shut it down right away. Less than 60s.
The 10V was on an old fluke DMM that I have used to troubleshoot my 9N, my Jubilee, and my 600. I'm not really buying this analog-meters-only argument, but I picked up a simpson 260 on fleabay and will try it again with that.
No ammeter on an 841- they substituted a gas gauge. I don't have a clamp-on so I'll have to kludge one up.
I assumed it was a B circuit based on the year but will reconfirm if you tell me how. It def has a 6V regulator.
thanks for the help!
soundguy
03-07-2014 15:29:36
 Re: Automobile genny on 841 - which VR and coil? in reply to William Fissell, 03-07-2014 14:26:21
I was kinda hopin you had an ammeter int he tool box to toss inline. they are great diagnostic tools. way better than a olt meter or idjit lamp if you can only have 1.
William Fissell
03-07-2014 16:23:04
 Re: Automobile genny on 841 - which VR and coil? in reply to soundguy, 03-07-2014 15:29:36
The genny motored with arm and fld to battery- I think that confirms its a B circuit.
soundguy
03-07-2014 16:44:14
 Re: Automobile genny on 841 - which VR and coil? in reply to William Fissell, 03-07-2014 16:23:04
generally yes.. however technically it should motor with just arm and case and residuals. but.. with 50ys of dirt and rust. many times it's not smooth enough to do so. ;)
William Fissell
03-08-2014 08:26:23
 Re: Automobile genny on 841 - which VR and coil? in reply to soundguy, 03-07-2014 16:44:14
OK, I have a lot of big black bird (crow) to eat. Turns out y'all were right and using an analog meter DID give me a different answer.
1- measured voltage with engine running about 800 rpm: 6.2V across (fresh) battery terminals. 6.2 V at the arm and at the field terminals of the genny.
2- looped in an old inductive ammeter between bat and battery, full fielded it by jumping arm to field, got the ammeter pinned. (pinned negative, but I probably have the inductive ammeter on backwards). I didn't measure volts because I only had 2 hands and I didn't want to drop my nifty new Simpson 260.
Attached is a photo of the genny.
