Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 4500 Parts Online
Re: 4500 with shuttle shift
el6147
03-07-2014 06:57:01
having done some research on the ford newholland parts , I see where there is the pick up tube and screen and two variations of the placement of the trans filter . owner stated that the tractor is currently outside and I have know way of knowing if it has always been stored outside and it is in a cold climate.
so has I understand it,the differential and trans share the same oil and it is used to supply the torque converter and the screen pick up is located at the bottom of the trans case. If it has been stored out side for some time that would make sense that the trans may have taken in rain water. further research as indicated that the 4500 shares many of the same shuttle parts with later built ford units . and the drive discs where also used on many john deere's also and many parts including the pump are available aftermarket.
JF in CT
03-07-2014 14:29:51
 Re: 4500 with shuttle shift in reply to el6147, 03-07-2014 06:57:01
I don't remember if the trans and diff share the same fluid, they may but I think they are seperate units with independent fillers. I could be wrong but you should check on that.
