TractorLinks.com
Order Ford 640 Parts Online
Re: Ford 640 gas shut off valve leak
Dean
03-07-2014 06:12:47
Use the proper (new) O ring, make certain that it is properly positioned and the mating surfaces are free of debris and do not overtighten. No goop.
It will leak if you do not use the proper O ring and/or the O ring grooves are not clean.
It will leak if the O ring is not properly positioned.
If you over tighten the bolts, you will damage the valve and/or tank and it will leak.
Dean
Jeeps
03-07-2014 07:50:20
 Re: Ford 640 gas shut off valve leak in reply to Dean, 03-07-2014 06:12:47
Makes sense.
Thanks Dean.
