Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 4000 Parts Online
Re: New to me Ford 4000 TLB, 4cyl, 1961ish??
TONY JACOBS
03-06-2014 20:12:53
Hello Chainsaw , Alan is the closet one to being right but not completely . You do have a 4000 Light Duty Industrial tractor it is a model number 4030 and was built between 1960 and 1962 . The Ford Loader NOT DEARBORN is a model 19-249 series 720 and lifts 2500 pounds . The backhoe is a Ford 19-300 12 foot dig depth series 723 . Cold Rolled steel is no good for the backhoe pin even if you have it hardened it is not strong enough to resist shearing and it will . No one makes a ROPS for those older models and there is basicially no where to mount one anyways that would do any good even if you could roll it over . You can get hydraulic cylinder packing repair kits at your local hydraulic shop , packings only go by inside and outside diameter measurements not by what they fit so those will not be a problem . Pertronix makes 12 volt electronic ignition kits and 12 volt charging can be done many different ways so that is also not a problem . You can also get a Blank Quick Attachment Plate and you will have to weld mounting brackets on to the back of it so you can mount it to the Ford Loader then you can attach any Quick attach implement to it . Where are you located ? Thanks Tony
