TractorLinks.com
Order Ford 5610 Parts Online
Re: 5610 PTO brake not braking
Bern
03-06-2014 18:03:13
Splitting a 5610 without dual tanks is a piece of cake. With air tools, I could have it apart in less than 30 minutes. It would be far preferable compared to dinking around through the 3-point top cover opening.
As Rod said, you MAY be able to fish it out through the top, but there's also a good chance you can't - I've never tried it. There's a very good chance you could waste several hours in that potentially fruitless adventure.
Also, you're supposed to adjust the new brake band with the band on the housing, which is something you cannot do if you go through the top.
The biggest pain with a rear split is joining the two cases back together. Do yourself a big favor and chamfer the splines in the PTO hub with a small grinder. This goes a long way towards making that job go much smoother.
RodInNS
03-07-2014 06:40:03
 Re: 5610 PTO brake not braking in reply to Bern, 03-06-2014 18:03:13
AS I've said, I've had the PTO control valve and band out the top on my 7710, so I know it can be done. I just forget exactly if it required pulling the rear shaft or not. On an open station 5610 the split is probably a lot easier. Not so much on a 7710.
Rod
dieselpup
03-07-2014 05:05:33
Ha, that chamfer is a good idea. When I put the 7701 back together last winter I finally pulled the hydraulic pump off so I could reach in and turn the shafts to line the splines up. But this looks much easier. No 4wd, no loader brackets to bang my head on, no platform to take off and like you said, no monster fuel tank on the side. BIL heard the word split and was worried. But it is far away the easiest tractor on the place to work on. Thank you for the advice.
