Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: 10 series 201 - oil in the water
03-05-2014 18:19:18
I've worked on more of those Basildon engines than I care to remember, and never have I heard of an issue with a cracked oil gallery putting oil in the water. To be honest, even if it was cracked, I don't think it's close enough to a water passage to do that.
Furthermore, I don't see how the oil gallery could be replaced with a tube because the lifter bores intersect the oil gallery. It would be darn near impossible to do. Are you sure you understood this repair correctly?
Back to your original problem: Pretty rare on that engine, since it does not use an oil cooler, unless the BSD engine came with one. Is there an oil cooler behind the oil filter? If so, have it checked very carefully, or take it off, it is not really needed.
How much oil in the cooling system are we talking? It doesn't take much to make it look like a lot. Is there no evidence of water in the oil? It's possible that a pinhole low enough in the cylinder wall could allow oil to be scraped into the cooling system I think.
Other than those 2 things (oil cooler and pinhole), I can't think of how a 201 could do that.
Ultradog MN
03-05-2014 18:48:55
 Re: 10 series 201 - oil in the water in reply to Bern, 03-05-2014 18:19:18
Thanks Bern.
I'm asking, not telling.
The old machinest who does Ken and my work told me about pinholing from the gallery into the water jacket. Described fixing them by reaming and installing a tube. I thought I understood him...
Said back in the 80s a couple of dealers couldn't keep 401s running because of it. He figured out how to fix them and made a lot of money buying 'junk' cores and fixing them that way and rebuilding them.
I could have sworn he fixed Ken's 201 from his 4600 that way for the same problem.
I didn't notice an oil cooler but will look if I see it again.
I meant BSD not BS.
03-06-2014 15:11:37
 Re: 10 series 201 - oil in the water in reply to Ultradog MN, 03-05-2014 18:48:55
I know many people who would refer to those engines as "BS". However, that description is more deserving for the 401, not the 201.
