The hydraulic (lift) is stuck in the up position and will not come down. I added fluid since it was low before I got the tractor started and it went up with lever down once the tractor was running. The fluid is a milky white which indicates water in the system. On the 8N page, http://www.oldfordtractors.com/rep.htm#q20, it says this is likely a stuck valve.
1. Where to start?
2. Drain and replace?
3. A similar discussion mentions a soundguy method to get the water out?
4. A simple method to at least get the draw bar lowered?
5. General thoughts on repair cost, time, etc?
Thanks.
1. Where to start?
Thanks.
