Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Order Ford 640 Parts Online
Re: Ford 640, lift stuck up
soundguy
02-28-2014 18:29:23
if you run it without oil you will ruin the 500$ pump bolted to the side of the engine.
if the lift is going max at start.. the unload valve is sticking.. you need to pull the lift cover to address it.
nytx
02-28-2014 18:45:03
 Re: Ford 640, lift stuck up in reply to soundguy, 02-28-2014 18:29:23
Thanks. I will fill it up and post back.
soundguy
02-28-2014 18:53:01
 Re: Ford 640, lift stuck up in reply to nytx, 02-28-2014 18:45:03
if you have to use it and need lift half up, run a hose from the 3x5 cover under the seat ( plug there ). and run it to the hyds sump fill, that will let pressure off the lift piston. then chain the lift arms to the axle with a block of wood under them to keep them at set height.
that willlet you drag a drawbar implement. and not ruin the pump. oil will cycle out of the top cover back to hyds sump under lefs side of seat ( fill hole )
nytx
02-28-2014 19:27:32
 Re: Ford 640, lift stuck up in reply to soundguy, 02-28-2014 18:53:01
Thanks. I assume you are referring to a hydraulic type hose with threaded connections/fittings at each end so I can attach them.
Do you think I could find a standard hose or need to have one made since I am guessing the fittings are different at each end? I know the plug size, but I will have to look at the tractor in the morning to find the fill hole you are talking about.
soundguy
02-28-2014 19:47:21
 Re: Ford 640, lift stuck up in reply to nytx, 02-28-2014 19:27:32
the top port is pipe thread, and the fill cap under yer left thigh is a bung opening. just cram the hose in there and stuff a rag around it..
Copyright © 1997-2015 Yesterday's Tractor Co.
